2013 Yamaha R6 - $8,250
2013 Yamaha R6 -$8,250
Located in DFW area
This bike won multiple CMRA Expert championships for 2022 including Middleweight #1, C Superstock, C Superbike, B Superstock, and B Superbike. This bike also ended the year CMRA expert overall #2. This bike is fast and dialed in!
I bought this bike from the original owner back in 2017. The bike was purchased and immediately converted into a track bike and only used a couple times a year before I bought it. Since I acquired the bike all work has been done by Jimmy Cambora (Raceworx) or by Steve Upchurch (RES). The bike was never registered so I have an MSO.
The forks and shock were refreshed and serviced in-between every race season by Jimmy Cambora since owning the bike.
The engine was completely rebuilt in 2019.
I replaced multiple parts for the 2022 season. Front brake calipers rebuilt and new ti caliper bolts. Front rotors and bolts replaced on both front wheels. Samco coolant hoses installed. New Water pump. New steel front and rear brake lines. New clutch cable. New vortex fuel cap. Jimmy replaced steering, swingarm, and wheel bearings. New dynojet push/pull quickshift switch.
Parts list:
Front suspension - AKGAS traxxion dynamics
Rear shock- Penske triple (will be freshly rebuilt with 0 miles!)
Bazzaz z-fi tc (1 pump gas map and 1 MR12 fuel map)
Translogic autoblip up/down quickshifter
Dynojet push/pull switch
Renthal clip ons
Vortex rear sets
Vortex fuel cap
Vortex sprockets
Vortex road racing chain
Ohlins steering damper
Brembo 19x18 master cylinder
M4 full exhaust
Slipper clutch spring modification
Vesrah ZZ brake pads
Sharkskinz superbike bodywork (see description at bottom)
GB case covers
Gutted thermostat
Safety wired for CMRA racing
Spares:
2 sets clip ons (1 vortex, 1 renthal)
Fairing stay
Front wheel with rotors
Rear wheel with rotor
New vortex 45 rear
Used Rental 43 rear
Used rental 47 rear
Front axle nut
Front sprocket nut
Rear axle nut
Oil dipstick
Shift rod
Seat pan (cracked)
Clutch lever (used) x2
Clutch cover oem
Clutch cover gasket x1
Generator cover oem
Generator cover gasket x4
Timing cover gasket x1
Used steel brake lines
Radiator cap x2
Brake reservoir bracket
Vortex Shift side rearset
Vortex Brake side rearset (scrapped peg)
Gb clutch cover
Gb timing cover
OEM R6 seat
Seat mount
Front fender
Supersport tail (uses oem seat)
Gas tank (dented but functional)
Fuel pump (used)
Fuel pump gasket new
Water pump (used)
Radiator (used)
Subframe (used)
Push pull shift sensor translogic (used)
Rear caliper holder
Windscreen (used)
OEM Air filter
Front sprocket 15
Pirelli rain tires front and rear
The only negative with this bike is the bodywork is rough. It is sharkskinz so it is good stuff and can be repaired. The upper is in the worst condition and is cracked in a couple different places. The lower is scrapped. The tail has a crack and some scrapes as well. I've been racing with it as is with the anticipation of repairing it over the winter. PM me if you are interested!
https://www.facebook.com/marketplace...ibextid=dXMIcH
