TWO 2021 Graves Kawasaki Ninja 400's built to MotoAmerca specs with spares
FOR SALE $27,000 Package deal with spares - TWO Graves Racing Services 2021 Kawasaki Ninja 400's built to 2021 MotoAmerica Junior cup specs including over $6000 in spares.
One was raced in 9 MotoAmerica Junior Cup rounds and 3-4 local events. The other is practically brand new with only 2-3 hours on it and then sat as a spare.
Both are identical with the exception of clutches and quickshifter and produce approximately 51 HP (stock is 45) and include:
● Restrictor Plate FlashTune Flash Upgrade ECU with 2021 Graves Map
● Graves Spec 2021 Ohlins NIX 22 Forks
● Graves Spec 2021 Ohlins rear shock with hydraulic preload adjuster
● 415 chain conversion
● Full build sheet with part numbers of specifications and full list of spares is available upon request
Facebook post with images
The full list of spares worth over $6000 includes a spare set of wheels and Galespeed rotors with mounted Dunlop rains, full Graves exhaust, full painted Sharkskinz bodywork and misc pieces, sprockets, chains, clutches, numerous takeoff tires (9-10) with 50% or more life left, etc is available upon request.
SPECS for each motorcycle (Graves Works parts except where noted):
• New non ABS 2021 Ninja 400
• 41mm riser Clip-On Handlebars (new spec)
• Renthal Firm Compound Grip Set
• Ohlins 68mm Steering Damper
• Kawasaki Ninja 400 Race Only - Stabilizer Mount
• Galespeed adjustable ratio, folding lever with perch clutch kit 32-34 (new spec)
• Steering Stop
• Progressive Throttle Tube
• Motion Pro Rev 2.1 Throttle Housing
• Motion Pro Throttle Cable
• Adjustable Rear Sets New Pricing updated parts
• Works Radiator Screen Ninja 400
• Engine Cover Set (Ignition cover, Clutch cover, Water Pump Cover)
• Brake Lever Guard
• Works Carbon (Shark) Toe Guard
• Graves Diamond Shape Works Frame Sliders
• Brake Line Kit (front and rear)
• Active short, adjustable, folding, replacement Brake Lever
• Gale Speed Master Brake Adjuster Cable and Perch kit (all master & Active w-wcy-17R6-01)
• Ninja 400 Galespeed Front Right Brake Rotor New
• Ninja 400 Galespeed Rear Brake Rotor New
• Rear Brake Return Spring
• Vesrah RJLZZ Racing Brake Pad Set
• Restrictor Plate FT Flash Upgrade (Graves Map) New 2021 Map
• Moto America Spec Shifter and RPM limit system
• EX400 AIM Solo/2/DL Power Cable - connect to harness (does NOT include the Solo itself)
• On Off Main Power Switch
• Ninja 400 Dash Bracket, Aluminum (allows use of standard fairing bracket)
• Rain Light with handlebar switch
• Smog Block Off Ninja 400
• DNA race Air Filter NEW
• Suter Slipper Clutch Kit Ninja 400 REPLACED by Yoyodyne slipper (Primary raced Ninja)
• EVR special 6 plate slipper clutch (Spare Ninja)
• Works 2.0 Bar Radiator Cap
• Full Exhaust System Stainless and Carbon Fiber (New spec 2021)
• Maxima 0-20 Race Oil
• Engine Build SuperStock Spec, includes gaskets
• Gear Box under cut and shim
• MB dual radiator
• Graves Spec 2021 Ohlins NIX 22 Kit Fork (with springs)
• Graves Spec 2021 Ohlins Rear Shock
• Hydraulic Preload adjuster (Original has no preload adjuster)
• Spring Retainer (required for Graves spring and Pneumatic or hydraulic Preload Adjuster)
• Works High Precision Racing Spring for Ohlins TTX GP rear shock 95n/mm
• 415 Front sprocket
• 415 rear sprocket
• 415 Chain (140 links will cover any combination and max length)
• Flange 16mm self locking axle nut set of 2 (new easier wheel changes)
• Works Aluminum Valve Stem set
• Front Wheel Spacer Set
• Rear Wheel Spacer Set
• Bodywork, Complete set
• Bodywork, Supersport Seat
• Seat Pad for Superport Seat
• Paint Bodywork Black inside and outside prep for stickers
• Graves Factory sticker kit
• Bodywork mount hardware Kit, 20 Pcs 1/4 turn fasteners, rivet, springs
• Fuel Cell Foam
• Light Tech Fuel Cap - TFN-223-NER New spec
• Black 8mm Spool Stand mounts
More pictures on the way soon
https://www.facebook.com/CaleEssmanR...TCefw5TTdLrmql
