Results 1 to 3 of 3
Thread: Newbie question on catch cans
    Hello- I'm prepping my Suzuki sv650 (2nd gen) for my first race. I have a question about what (if any) catch cans are needed.
    Radiator- The drain hose comes out of the overflow tank, so it doesn't need another overflow tank, correct?
    Crank case breather- Vents into the unmodified airbox
    Gas tank ventilation- Two hoses, one connects into the radiator drain hose, the other is separate. Both would end of draining into the belly pan.
    Will this pass tech or do I need to add catch cans?
    Thanks!
    no others are needed...
    Junior Member Steve Hanson's Avatar
    Mar 2013
    Either AZ, CO or CA
    Not final but this is my setup on my 2nd gen SV.
    Sent from my SM-G960U using Tapatalk
