Is the 390 Duke the same chassis, motor, suspension as the RC? A friend of mine is selling a 390 Duke cheap, but I'm not sure If I can make it a race bike. Anyone one know the differences other then the obvious.
At the very least the frame is different between the two - Duke does not have the integral (not bolt-on) tailpiece extension welded as part of the trellis that's integral with the RC 390/ RC Cup.
Alan Etheredge, Associate and Interested Observer ~2003-2019
At-Track Registration Staff ~2003-2017; CMRA Administrator 2009.
RC390 vs Duke 390
As Alan said, obviously the tail is different. It also looks like the radiator on the Duke is a bit smaller, the airbox is obviously totally different, and some electrical stuff has at least been moved around. But you can look up part numbers on bikebandit or something like that to find out exactly where the discrepancies are.
The steering head numbers are different on them. 65 on Duke and 66.5 on RC. I don't have the trail number on the Duke but I'm sure they are different.
Here are the numbers on the RC390.
Chassis
Frame Steel trellis frame, powder coated
Subframe Steel
Front suspension 43mm fully adjust USD WP Suspension
Rear suspension WP Monoshock, fully adjustable
Front brake Four piston, radially bolted caliper, brake disc 300 mm
Rear brake Single piston, floating caliper, brake disc 230 mm
ABS Removed to save weight
Wheels front/ rear Cast aluminum wheels 3.00 x 17”; 4.00 x 17”
Tires front/ rear 110/70ZR17; 150/60ZR17
Chain PowerParts racing specification
Steering head angle 66.5°
Trail 88 mm
Wheel base 1340 ± 15 mm
Ground clearance 178.5 mm
Seat height 820 mm
Tank capacity Approx. 10 liters
Numbers for the Duke can be found here.
http://www.ktm.com/ca-en/naked-bike/390-duke-2016/
Private lessons available at MSR and ECR
One on One or groups up to 5 students
Email typhoonpowersports@yahoo.com or visit me on Facebook.
Thanks Ty. I don't think I'm gonna but it. Looks like to much work to get it race ready.
What did you choose? Please write.
