Race prepped 2015 Yamaha R3 for sale. It was an insurance salvage bike that had 2295 miles when I converted to race trim around this time last year (May 2017). I've only ridden it 4 or 5 race weekends since then. I managed to run off track at TWS in the chicane last season, so its been low-sided once in the grass, with minor damage to the bodywork, exhaust can, and the rear brake lever (and my pride took a hit as well).
$5500 for everything.
PM or text 281 sixonenine 44 sevenone
The bike has had the following done to it:
Full M4 stainless exhaust
Power Commander V
Auto Tune for the PCV
K&N air filter
NortonFab smog block off plate
GB Racing case cover kit (alternator, clutch and water pump)
Graves lightweight aluminum fairing stay
Graves fairing stay mount kit
Graves R3 steering stop
Fast From the Past steering damper fork mount
OEM GSX-R600 steering damper
K-Tech cartridges
JRi triple clicker rear shock
Galfer/NortonFab superbike SS front brake line
Braking front brake rotor
Vesrah front brake pads
Axles drilled for safety clips with castle nuts
Graves chain adjuster retainer set
415 chain conversion
Motion Pro Rev2 quick turn throttle assembly
Woodcraft clip-ons
Woodcraft brake lever guard
Map switch for PCV/Auto Tune
Woodcraft adjustable rearsets
Woodcraft folding toe piece for gear shift lever
Hotbodies bodywork
Zero Gravity Double Bubble windscreen
Hard-wired LED rain light with handlebar on/off switch
External USD port for connecting to PCV
Fully safety wired
Spares and extras to go with the bike:
Original stock front rotor (good condition)
Full set of 415 sprockets for CMRA tracks (17-18T front, 54-57T rear)
2 new-in-box DID 415ERZ chains (including master links)
5 new-in-bag DID 415 master links
Spare Hyperco 950 lbs/in spring for JRi shock
New-in-box Hi Filtro oil filter
Original stock air filter (good condition)
Yamaha factory service manual
New-in-box Woodcraft folding toe piece (intended for the brake lever on the bike)
Used Woodcraft fixed toe piece (good condition, was originally installed on the gear lever on the bike)
Spare throttle reels for the Motion Pro Rev2
Original stock gauge cluster (has an intermittent short affecting the tach, so was replaced with the eBay unit installed on the bike)
Original stock fairing bracket (slightly bent)
New-in-box clutch cover gasket
Original stock throttle tube assembly with cables and RH switch housing (good condition)
Original stock rear shock (good condition)
Original stock rear brake pedal (good condition)
Original stock gear shift lever (slightly bent)
Original stock LH switch pod (good condition)
Original stock kickstand, spring and bracket
Original stock 520 sprockets
Pit Posse dual temp tire warmers (120/160 size)
New Pirelli Diablo rain tires (unmounted) with storage covers
(Rear stand and wash plug in photos below are not included with the sale.)
