2015 Ninja 300 Track Bike
Only 1375 miles. Excellent condition. Never been down. No scratches or blemishes. Runs perfectly. Currently configured for track use but can be converted back to street use if desired (all original parts provided). Clean title. Many modifications listed below. Suspension setup for 195 lbs:
-Brembo RCS14 Master Cylinder
-Spiegler Stainless Steel Front Break Line
-Area P Full Hi-mount Exhaust System with Fuel Moto Micro Tuner / Programmer setup by Area P
-CNC Aluminum Shorty Short Clutch and Brake Levers
-JRI Double Adjustable Rear Shock w/ Remote Adjustment
-Sato Racing Fork Spring Preload Adjusters
-Race Tech Caddies Gold Valve Cartridge Fork Emulators
-Race Tech Fork Springs - .80 kg/mm
-Vortex RS424K Black Rear Set
-Second 'smokey' windshield available
-Woodcraft Racing 3 Piece Split Clip-on Handlebars
-Pirelli Diablo Rosso II Front and Rear tires (BRAND NEW - only one ride on them)
-90 degree valve stems
-I.D Pro-Street X-Ring 520VX2 108 Link Chain
-Vortex (435ZR-45) Red 45-Tooth 520-Pitch Rear Sprocket
-Vortex (435ZB-44) Blue 44-Tooth 520-Pitch Rear Sprocket
-GPR V4 Steering Damper
-Woodcraft break lever guard
-Heal-Tech GI Pro Gear Indicator
-Kawasaki OEM Seat Cowl
-Tank grips
-Woodcraft Frame Slider Kit
-Woodcraft Key-switch Elimination Harness
-Driven HALO keyless fuel cap and base
See pictures here:
https://www.cycletrader.com/listing/-5005108422
If you part it out, I'll take some stuff... just sayin.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
