Hey guys, after a ride i had couples weeks ago the battery drain its charge. I know the typical issues for first generation R6s so i started checking R/R and stator connectors. I found the stator 3 pins connector with the plastic case melted inside. Before fixing that i replaced a blown 30 amp fuse from the starter relay. But i dont know why the fuse keeps blowing out. Is there any part causing them to blow?.
