Thread: WTB 2G SV650 single plug engine
    Looking for a stock SV650 engine to put in a street bike. I believe the single plug configuration is 2003-06. Some mods are allowed as long as it remains a SS eligible engine in case I decide to make it a B bike or just to run the SS class.
    I have a 2003 engine in my garage. I looked at it last night and thought I should use it for a project, but I also need to clear out my garage. $100 to you.
    Full disclosure:
    1. I pulled it before ever racing because it sometimes popped out of 2nd gear after a 1-2 shift
    2. One of the bolt holes for the front header isn’t perfect but holds a bolt fine. A bolt had seized in it and I had to surgically remove the bolt.
    3. No throttle bodies.
    Otherwise, it is an excellent engine
    As long as it will run, I'll take it.
    Josh - PM sent
