Results 1 to 2 of 2
Thread: FZ-07 MotoAmerica Twins Superbike, LOADED!
    Senior Member Ryan Max Johnson's Avatar
    Oct 2008
    Weatherford, TX
    As raced (and won) by Draik in MotoAmerica. Fully loaded, as good as it gets for the Yamaha FZ07/MT07 Twins Cup Superbike. Engine and suspension only have a couple MotoA rounds. Bodywork has brand new, high quality paint job. have never raced this bike.
    This bike should dominate most club twins races and be very competitive in MotoA.
    Specs as written by Draik:
    2017 Yamaha FZ-07
    Robem Engineering adjustable triples(comes with multiple offset inserts)
    R6 K-Tech RDS Front Forks
    GSXR-600 K-Tech DDS Rear shock with Pro Bypass
    Robem Engineering Rear Linkage Sysytem
    Aluminum Subframe
    Lightweight Wiring Loom
    Rain Light
    ARacer ECU
    ARacer Quickshifter
    ARacer Display(with on the fly map changes)
    ARacer Button Cluster
    ARacer GPS
    ARacer Bluetooth Dongle and Red Access Cable
    Woodcraft Clipons
    Woodcraft Frame Sliders
    CRG RC2 Clutch lever
    CRG Raceline Billet Lever(rashed)
    Radiator Guard
    Lightweight TXP Pegs
    Brembo 19 RCS Mastercylinder
    R6 Calipers With Titanium Bolts
    Underslung Rear Brembo Caliper
    R6 Wheel Conversion
    Roaring Toyz Rear Axle Blocks
    Welded Spools
    GB Racing Shark Guard
    Stainless Braided Brake Lines(Front and Back)
    R6 Quarter Turn Throttle
    520 Regina Chain
    Bored Throttle Bodies
    Carbon Fiber Air Intake system
    Adjustable Aluminum Velocity stacks
    Ported Head
    Lightweight Flywheel and Sprag.
    Backcut/Shimmed transmission
    Carrillo Rods
    Weisco Pistons
    Webcam Cams
    Stiffer Valve Springs
    GB Racing Case Covers
    Full Yoshimura Alpha Exhaust System
    Title in hand
    ...and with OZ lightweight aluminum wheels!$$$$
    $12,500 for this awesome machine.
    Inquire if you’d like more pics or videos. Bike gets started/runs a couple times a month.
    -RMJ96-
    Armour Bodies | Bazzaz | Dunlop | Bison Track | Motion Pro | Vesrah | Vonhertell | Sidi | Woodcraft | 6D Helmets | Woods Cycle Country | Magura
    This bike is fast!
