2012 Triumph Daytona 675 Part Out
Here is a list of parts I have for sale and the price for each one. Let me know if you are interested in any of them. I will post whatever is left on Ebay next Monday:
Rear Wheel w/rotor $120.00
Front Wheel w/Rotor $250.00
Front Wheel w/o Rotor $180.00
SharkSkinz Race Fairing (Upper, lower, tail, fender) $350.00
Windscreen (Dark) - broken tabs $30.00
Windscreen (Clear) - never used $50.00
Yoyodyne Slipper clutch with basket & plates $500.00
Ohlins Forks (serviced and setup by Jimmy Cambora) $1,200.00
Ohlins Rear Shock (Services and setup by Jimmy) $450.00
Brembo Brake w/Vesrah Race Pads $400.00
Instrument cluster, ECU, Ignition, Gas Cap, Rear lock $700.00
Frame (Clear Title, neck work) $200.00
Frames (No title) $200.00
Swingarm $140.00
Subframe $125.00
Rear brake caliper (Nissin) $20.00
Radiator w/fan $180.00
520 Chain w/ Sprockets (16 F - 48 R) $150.00
Acropovic Exhaust System (Full) $1,000.00
Gas tank $250.00
Starter Motor $150.00
Motor (parts only) $500.00
Vortex Rearsets $300.00
Airbox w/ Throttle bodies & Full injectors $200.00
Front brake master cylinder w/ lever $200.00
Bazzaz Zfi w/Quick shifter $300.00
Water Overflow reservoir $20.00
Kickstand $50.00
Crankcase Cover $65.00
Front and Rear stands $60.00
TRS Pin set $50.00
Seat $85.00
Wiring harness $140.00
Adjustable vortex clipons $75.00
Hyper-Pro Steering stabilizer $50.00
Motion Pro Quick Action Throttle kit $100.00
Ram Air Intake tube duct $170.00
Air sylenoid valve assembly $20.00
PM me, call me, or text me at 682-459-7158 if interested in anything.
Here is an updated list of the remaining parts I have for sale and the price for each one. Let me know if you are interested in any of them. My contact info is at the end of this post: PRICE REDUCTION: - Take 10% off each item, as I need to get them sold.
Rear Wheel Spare $120.00
Windscreen (Clear) - never used $25.00
Swingarm $140.00
Subframe $125.00
Kickstand $50.00
Seat $85.00
do you still have the sub frame for sale?
Yes I do. Text me at the number above.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
