2015 Ninja 300 $2100
2015 ninja 300 9,650 miles. Abs model. Was going to convert it to a track bike so took fairings off. The previous owner dropped it apparently on multiple occasion but it’s all there including headlight if put back on could pass inspection. Have a brand new set of hot bodies fairings in primer in box. Had the ecu flashed by Spears Racing not cheap. Has voodoo rearsets. Have woodcraft clipons that were a backup set for another bike. No suspension work done but I have a hertell frankenshock (set up for heavyweight) off a 250 that I was going to install but needs serviced. Also have a complete set of spare forks with triple clamp off a 250 that comes with it. Has a Leo Vince slip on can with the db killer Spears says it need that restriction. But I have a two brothers header with muffler used road rashed has cat delete but think it’s missing a mid-pipe. Text if interested will get back to you ASAP. 830 Seven zero eight 506 two.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
