Results 1 to 3 of 3
Thread: 2015 R3 Engine (cracked case) and frame (bent)- free
    This is from a crashed 2015 R3. The frame is bent, and the engine case is cracked at the mounting point. All that's left is the engine, frame, tank, and front and rear brake calipers. Won't start due to the crack in the engine case, but the internals shouldn't be damaged.
    Just wanted to see if anyone was interested before taking it to the scrap yard.
    Located in Richardson. Must pick up. Bring a friend to help load it since there are no wheels/suspension.
    Dec 2018
    Weatherford, Texas
    Scott, Did you get a replacement? Hope to see you next year.
    Quote Originally Posted by Joel Linker View Post
    Yep! I'll be out there
