First Gen Superbike - $3900 - New Orleans
Selling because I want to clean out my garage a bit. I just got another bike so one has (should) to go.
Straight and Sorted SuperBike SV
GMD built Showa 2001 GSXR 750 forks aftermarket anti-friction coating, extenders,
valving.(9.5kg springs)
GMD Billet adjustable triple clamps
Penske Triple adjustable shock (650 lb spring)
Ohlins linear steering stabilizer
Brembo 2 Piece Billet GP front brake calipers with Performance Friction pads (Full race not
OEM)
Brembo radial master cylinder (Full race not OEM)
Powder coated frame and swing arm
5.5" Rear GSXR wheel
Captive Spacer kit front and rear
Engine
Spears Spec 2MM over Superbike engine, JE Pistons, Magnafluxed, lightning, Shot Peen,
Balanced, Full Superbike head work/ Valve Job from Edco etc. Mega Cams. Makes 83-85 hp
Yoyodyne Slipper Clutch
41mm Keihin FCR flatslide carbs
Full Akrapovich Titanium exhaust
Pace Superbike radiator (SV specific )
Woodcraft clutch cover
Sharkskinz bodywork in good shape
tank has dents but plenty functional holds fuel no problem - I'll include another tank
TransLogic Factory Quickshifter specifically designed for first generation SVs from Spears.
GP Tech faring stay
Lightweight Aluminum subframe
SPA tachometer with temp and programmable rev light
Vortex keyless gas cap
Woodcraft frame sliders, Clip-ons,High rear sets, Hand guard
Adjustable Folding levers
Galfer Front Wave rotors
Drilled rear rotor
Shorai lightweight battery with Total loss charging system
MotionPro Quickturn Throttle
Recently serviced by Vinnie at Pro-Line Race Prep
I will work with you on shipping.
https://www.dropbox.com/sh/wxz...AAD...Rh3qxb7va?dl=0
Sent from my Pixel 5a using Tapatalk
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
