2004 Suzuki SV650 Superbike
For Sale: 2004 SV650 Superbike
$5,000 Firm
Bill of Sale only, clean VIN
I do not have dyno numbers on this engine but it will be mapped for U4
Motor:
Freshly built motor, all tolerances checked
13:1 +2mm JE Pistons
Carillo H beam rods
Steel Oil Pump Gear
Lightweight Flywheel
3rd Gen Intake Cams
TWF Valve Springs
Mega X15 intake cams on exhaust side (can throw in 2nd Gen intakes or exhaust cams if desired)
Adjustable Cam sprockets
PSR Manual Cam Chain Tensioners
Full M4 exhaust
ARP Studs
Cylinders were milled .015” by previous owner
DL1000 Throttle Bodies and mounting kit
Secondary blade delete with code eliminator
Motion Pro throttle with cables
Comes with both 1000 injectors and stock 650 injectors
Stock TB’s can be included.
Suspension/brakes:
06/07 GSXR front end with AK-20’s done by Raceworx. Fresh fluid.
Clip-ons and adjustable rear sets
Fork Cap extenders
Brembo RCS 19 Master Cylinder
R6 Calipers (recently done)
Steel Braided Lines
Penske Shock
Suspension is sprung for about 210lbs
GSXR rear wheel conversion
Electronics:
Power Commander 5 tuned for U4.4 by Raceworx
Autotune
Quickshifter
Secondary Eliminator Box
Race Harness
Silicone Radiator hoses
GSXR Body work and fairing stay
Frame Sliders
Tank is dented but works fine.
The bike is fast and handles extremely well.
I’m unable to upload any photos at this time
Feel free to text me for pictures and with any questions or inquiries @ 254-339-4401
Bike will be available at MSRH
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
