MARSHALING POSITIONS AND REQUIREMENTS:
FLAG MARSHAL - DISPLAY FLAGS TO COMPETITORS / COMMUNICATE WITH RACE CONTROL.
TRACK MARSHAL – ASSIST COMPETITORS AFTER CRASHES / RETREVE CRASHED MOTORCYCLES / COMMUNICATE WITH RACE CONTROL.
  • PLEASE FOLLOW THESE INSTRUCTIONS TO SIGN UP:
    • REGISTER FOR THIS MESSAGE BOARD. (NOTE: You must use your real first and last name as your user name.)
    • LOG IN.
    • POST AND PROVIDE ONLY THE FOLLOWING INFORMATION:
      • FIRST AND LAST NAMES OF EACH WORKER
      • DAY OR DAYS EACH WORKER IS REQUESTING TO WORK
      • REASON FOR WORKIN: PROV-NOV / CASH / SUBSTITUTE / FRIDAY PRACTICE VOUCHER
      • MARSHAL OR FLAGGER (NOTE: IF YOU ARE SIGNING UP TWO PEOPLE FOR THE SAME CORNER...YOU CANNOT BOTH BE FLAGGERS.)
  • ONCE YOU POST...WE WILL SEE IT...PLEASE DO NOT RE-POST. WE WILL CONFIRM YOU AS QUICKLY AS WE CAN.
  • PLEASE DO NOT SEND PRIVATE MESSAGES...IF YOU NEED TO ASK A QUESTION, SEND AN EMAIL TO...walter@cmraracing.com
  • ONCE YOU HAVE SIGNED IN AND RECEIVED CONFERMATION ON THIS THREAD, YOU WILL BE PLACED ON THE GATE LIST. GIVE THE GATE STAFF YOUR NAME AND YOU WILL RECIEVE FREE ENTRY.
  • CHECK IN FOR MARSHALS IS 6:30AM EACH MORNING. PLEASE BE ON TIME! AFTER 6:45AM YOU ARE LATE!
  • BE PREPARED TO GO TO YOUR STATION AT THE CONCLUSION OF THE BRIEFING. THIS IS NOT THE TIME TO GO PACK YOUR STUFF.
  • YOU MUST BRING YOUR OWN COOLER, CHAIR, DRINKS (OTHER THAN WATER), AND SNACKS. WATER WILL BE PROVIDED.
  • THE CMRA WILL PROVIDE LUNCH AND ALL OTHER NECESSARY EQUIPMENT.
PROV-NOV'S MUST WORK THE REQUIRED FRIDAY/SATURDAY/SUNDAY. IF YOU CANNOT...HERE ARE THE EXCEPTIONS:
  • YOU MAY USE A SUBSTITUTE YOU FIND TO WORK ONE OF YOUR DAYS.
  • YOUR SUBSTITUTE CANNOT COME FROM OUR REGULAR WORKERS, SO PLEASE DON'T ASK.
  • YOUR SUBSTITUTE MUST BE EQUAL IN ABILITIES TO PERFORM THE TASK.
  • YOU CANNOT WORK WITH YOUR SUBSTITUTE.
  • YOUR SUBSTITUTE MUST WORK THE DAY YOU WERE REQUIRED TO WORK.
  • YOU MAY WORK TWO SATURDAYS OR TWO SUNDAYS ONLY IF MILITARY, OR IF EXTREME SPECIAL CIRCUMSTANCE EXIST.
  • PLEASE DO NOT SIGN UP IF YOU CANNOT COMMIT. YOUR RESERVATION TAKES AWAY A SPOT THAT SOMEONE ELSE COULD USE AND CAN POTENTIALLY LEAVE US SHORTHANDED.
  • IN MOST CASES WE CAN ONLY USE TWO PEOPLE FOR EACH CORNER, EXCEPT ON FRIDAYS WHERE WE MAY ONLY USE ONE PERSON PER STATION. PLEASE BE PREPARED TO BE SPLIT UP IF YOUR GROUP HAS MORE.
  • IF YOU HAVE NEVER WORKED FOR THE CMRA, WE MAY ASK FOR MORE INFORMATION FROM YOU BEFORE SIGNING YOU UP.
DAILY RATE:
  • Flag and Track Marshals are paid $100 per day.
PRACTICE VOUCHER:
  • Instead of cash, riders can sign up for a Friday Practice Voucher.
  • 1 full day of marshaling =1 Friday Practice Voucher.
  • Marshaling can be completed Friday, Saturday, or Sunday for Friday Practice Vouchers.
  • Practice Vouchers are good for CMRA run Friday Practice only.
  • Practice Vouchers are non-transferable.
  • If a friend or spouse is working for a rider, they must declare that person's name for the Voucher.
  • The Marshall Coordinator issues the vouchers, it is the rider's responsibility to submit vouchers to registration. The CMRA DOES NOT keep copies of vouchers that have been issues.
  • Vouchers expire 1 year from the date of issue.
WE WILL DO OUR BEST TO ACCOMMODATE SPECIAL CIRCUMSTANCES, BUT CMRA NEEDS WILL DICTATE HOW WE ASSIGN YOU ON RACE DAY. CORNERS AND WORKING WITH WHO YOU CAME WITH ARE NOT GUARANTEED. SAFETY WILL DICTATE WHERE YOU ARE ASSIGNED. THANK YOU FOR UNDERSTANDING THIS REQUIREMENT.
WORKERS NEEDED FOR ECR:
SATURDAY WORKERS NEEDED: 10 FLAGGERS AND 5 MARSHALS
SUNDAY WORKERS NEEDED: 10 FLAGGERS AND 5 MARSHALS
