Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 88
Thread: Tech clarifications, oil filters and bellypans
  1. #21
    Senior Member Roger Albert's Avatar
    Nov 2005
    Austin, TX
    Re: Tech clarifications, oil filters and bellypans
    Thanks both.
    Look forward to the pix David.
    I don't want to end up in the problem child category with Kevin or the Dereks.
    OnRoad OffRoad Suspension - Ktech, JRI, Penske, Öhlins, MUPO, GP Suspension, RaceTech
    512 636 0960
    www.ororcycle.com
  2. #22
    Nov 2005
    Austin, TX
    Thanks both.
    512 636 0960
    www.ororcycle.com
  3. #23
    Roger-
    Sorry for the delay, I kinda forgot about this thread... Derek, I hope you don't mind the slight threadjack.
    Here are a couple of pics:
    From the bottom:
    From the right side: (Note the safety wire is actually attached to two small bolts, holding them in place as well. Some clever previous owner did this.)
  4. #24
    Roger-
    From the bottom:
  5. #25
    Nov 2005
    Austin, TX
    Thanks David. I too apologize if this was a threadjack. I'm hoping given the number of SVs, and the number of relatively new folks on them, that it's ok and useful though. I now have mine like that, and have an idea for an even more parallel one using the starter bracket. That soft metal drills like lemon merengue.
    Mmmmm. Piiiiiie.
    512 636 0960
    www.ororcycle.com
  6. #26
    Nov 2005
    Austin, TX
    Mmmmm. Piiiiiie.
    512 636 0960
    www.ororcycle.com
  7. #27
    Roger - I don't tech bikes. I think you have me and Heaton confused.
  8. #28
  9. #29
    TX
    Sorry NNNolden, but I got out my protractor and I'm measuring a 21.5 deg angle between that safety wire and the tangent to the oil filter hose clamp. I'm gonna have to protest your entry at the next race. Sorry.
    And you call yourself a chemist/metallurgist/computer network expert/safety wirer extraordinairre/HI Express stayer.... Sheesh. [img]/ubbthreads/images/%%GRAEMLIN_URL%%/wink.gif[/img]
    David B.
  10. #30
    TX
    David B.
