Ducati 848/1098/1198 stuff
Cleaning out the garage
stock complete 848 exhaust with ecu. $20
rear subframe. Off 848 but suspect it will fit other xx98. Brand new. $75
ohlins valving and springs for Showa 848 forks ( 215 weight rider) $50
stock 848 Sachs shock. New. $50
Bump
need room in the garage.
make me an offer
I will take the stock exhaust and ECU.
Bobby. I have someone who wants the ECU. Would you still want the exhaust without the ecu? Honestly you can have it just to give it a good home!
Actually all I wanted was the ECU.
I'll take the stock exhaust and shock. MSRH works. Look for the big black BRAWP bus.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
