2018 Yamaha R3 MotoAmerica spec - $6500
R3 ready to race. Motor had 4 MotoAmerica rounds on it. Since I bought it from John Deustschlander I added new Graves bodywork (never down), had the Front and Rear suspension refreshed (set up for 185lbs) and added bar risers to keep my belly off the tank. Also comes with a spare set of brand new wheels and Dunlop wets (never used). I could do the homework but suspect it has less than 5 sprints on it since I got it. I have the title in hand plus the Graves paperwork and handbook. Fresh oil and filter and it will be at MSRH. It's quick
Graves Bars/ Bar Clamps
Ohlins Steering Damper
Graves Damper Mount Kit
Graves Steering Stops
Graves Rear Sets
Galespeed Adjustable Clutch Lever and Perch
Graves Progressive Throttle Tube
Graves Stand Mounts
Braided Brake Line Kit
Graves Frame Sliders
Graves Left Side Engine Cover
Carbon Right Side Engine Cover
Carbon Shark Chain Guard
FT ECU- Currently with Moto America/Graves Spec Flash
HM Quick Shifter-Rev Limit Adjustment w/Moto America Spec
Graves Smog block off
Suter Slipper Clutch
.25mm Head Gasket
Adjustable Cam Sprocket
Full Graves Stainless Exhaust w/ Carbon Silencer
Ohlins Rear Shock- With Hydraulic Preload Adjustment
Ohlins Fork Internals
Front Wheel Captive Spacer
Rear Wheel Captive Spacer
DID 415 Chain
Graves Tank Cap
Fuel Tank Foam
Zero Gravity Wind Screen
Graves/Sharkskinz bodywork
Quick Release Upper Fairing Mount Kit
Works Radiator Screen
Radiator Cowl
See if this works;
https://imgur.com/gallery/OCWmAsc
