12 Attachment(s)
FS: 2006 Suzuki SV650S Race/Track Bike
For sale is a 2006 Suzuki SV650S model race/track bike with 23,800 miles on the odometer, most of them on the street. It was raced at Hallett a couple of times by the original owner, then a handful of track days by the second owner. I was going to do coaching on it this year, but decided to go a different direction. It has Traxxion AK-20 cartridges in the forks, and a Penske shock with remote reservoir, preload, compression, rebound and ride height adjustment. The bike is fully safety wired and CMRA tech-ready.
The bike has a Yoshimura slip-on exhaust system with a short carbon canister, and a K&N filter in the stock airbox. It has braided brake lines and good pads front and rear. I converted the bike to ‘sit-up’ style, with K&N superbike handlebars in a standard SV650 top triple clamp, so it can be ridden all day long during track days, with an oil containment lower mounted. The Woodcraft clip-ons and handlebars, full upper and lower fairing and front bracket all come with the bike if you want to convert it back. The bike has Vortex rear sets, a brand new DID 520 ERT3 gold chain, new sprockets, a front brake guard, adjustable front brake and clutch levers, an aluminum fork brace and a steering damper mounted behind the front number plate. It also has a keyless gas cap, a Woodcraft key switch elimination harness, and a pigtail battery connector for a trickle charger.
It has a new AGM battery and a brand new, never used fresh set of Dunlop 120/165 slicks on it. I didn’t plan on teaching or racing in the rain. The bike has a new fuel pump and the compression and valve clearances have all been checked, and all are in spec. The bolt-on side stand can be used for track days, then removed for racing.
It has a clean Texas title.
This bike has been gone through from front to back and is ready to go!
$4,900
Call, email, text or PM me.
Bill Syfan
817 fivetwotwo 2241
bsyfan at gmail dot com
Attachment 2452
Attachment 2453
Attachment 2454
Attachment 2455
Attachment 2456
Attachment 2457
Attachment 2458
Attachment 2459
Attachment 2460
Attachment 2461
Attachment 2462
Attachment 2463
