Like Proler's virginity
well, as many know, I about mechanically un-inclined as one could be.. trying to upgrade my air intake... but something just isn't right.
Is this tube facing backwards the air intake? http://i1077.photobucket.com/albums/...g?t=1408219517
and this the "air box" (as in box that the air filter resides)? http://i1077.photobucket.com/albums/...g?t=1408219525
and if that is correct, why is oil dripping out of there when I loosen the screws... if not, what is it?
That is the air box. I just removed mine today; however, I'm letting Ryan Andrews do the mod since it requires some crafting to use the K&N filter without it.
ya, I finally figured that out... man, there was a bit of oil in the bottom of the airbox. I almost have everything connected... almost.
I took all that stuff off.
You can then turn the intake around ( requires some minor wire/ cable re-routing) and the K&n fits right on. You can fit the K&n without turning the intake around but it doesn't look as cool! No performance advantage either way as best I can tell.
Put brake lines on mine last week... Like you need brakes......
My onboard video from the July round at Texas World:
http://youtu.be/hOGI08X4Tcs
