Originally Posted by
Greg Phillips
Walter,
No rose pedals are needed, I am not asking for any type of praise of any kind because I wouldn't even know what I would have to done to deserve it. The reason for my "try" is because without the help from the people who know how the back end works I would be limited in what I could do to try and help get something made. While I can completely understand and know from trying to work with him that Ted has put in a fair amount of time and work so I am not discrediting that in any way. No one is coming in and trying to reinvent the wheel with this process, but based on what you are saying 4 others tried to come in and change the way you do things internally rather than build on what you had. I think from my end at least that is what I have tried to approach this situation in the past with. I went through Linz to try and get a hold of the people who know the process to try and understand how things worked and how a system could be built to make life easier from both sides. I just have my opinion from the outside and as I have said before I do not know all the internal workings and what is going on behind the scenes. But if this option was something that was wanted to be looked into further I don't see why the process of how things work wouldn't be made more transparent so maybe others from the outside can help formulate a solution that doesn't break the current flow of things.
I have no doubt you are a smart guy and good at what you do, if I implied other wise my apologies. But even other greats who are smart in their fields and areas of expertise sometimes need an outside eye or opinion to see things from another p.o.v. I know you are very well connected and known in the motorcycle world and keep up with technology and standards. Let me preface this by saying again I do not know the inner workings of everything , but WERA launched their online registration in 2010, and from my research there weren't many complain about modernizing the system. I believe from some of your former post you are tied in with AMA as well, they use online registration for riders and teams as well. I am not discrediting your 20% , but at the same time I am interested in what the results would be on this forum alone if polled if they would rather use an online system vs the current process.
I understand that may be the final answer this is your organization not mine, but I am just using the messages boards to have a discussion that is all.
