I will echo the above... running stock pads and have had no issues on the big tracks, but, I have cooked them straight off on the kart tracks... of course, I was going spaceship speeds... I will be trying DP pads provided by Roger at OnRoad OffRoad Cycles next weekend... either DP or Vesrah, Roger or Mitch, you won't go wrong... both are top notch and always there at the track to help you out despite being a ginger and a raving lunatic respectively...
steel lines are overkill on the stock front end... you can not even use the stock set up with the front end as is... apparently, they are set up for someone Otto’s size…
finally, you must kiss the hand of Ryan, because he is the...
http://imagizer.imageshack.us/v2/280...0/840/h8u9.jpg
