Is water / water vapor somehow eliminated as a variable in this experiment?
Did you run each test, say 5 times, then throw away the largest and smallest result? :) Sounds like you didn't account for variations in moisture across the tests.
If you're really interested in "testing" the affect of moisture on pressure change. Start with a control of a dried tire and rim. Repeat with a dry tire and rim adding known increments of water for each test. As long as you get a baseline, it shouldn't matter whether you use compressed air from the same compressor or nitrogen. Is the shop climate controlled? :)
I was really hoping to read about something exploding..
Could be, this is all a see when I'm on the same track with him.....
http://i1098.photobucket.com/albums/...psf1ccfdd2.png
Mr Wizard saved Tutor Turtle from lots of bad situations. It's a compliment........in some cultures.
Here Mitch hold my tin hat for a second...I'm really avoiding this because I'm sure there are GP teams intensely awaiting a discovery but...
"air" = ~78% nitrogen
volume inside the bead sealed tire doesn't change (negligibly) and the gas volume required to raise the pressure from standard to operating doesn't quite double so unless you have a vacuum in the sealed tire before filling with gas you're never more than ~90% nitrogen. Which is probably a good starting point for negotiations at the tire shop when they offer it for an extra charge. If any of this is wrong I don't want to know it because it plays no bearing on selling smoothies.
In summary, put an appropriate amount of air in your tires and go ride.
Now give my hat back Mitch.
His cat's breath smells like banana strawberry cat food.
