This is the 1190 RS. If you're in Austin for F1 this weekend (which of course you won't be because you'll be at the Banquet), stop by the downtown location and check it out.
http://www.af1racing.com/ted/1190RS.jpg
Awesome! Is it going to be around for awhile?
I have to say it made me cringe seeing it held in with the bar straps. I've been using my PB Trailer Restraint so long that anything less looks abusive!
It will be there till someone lucky person buys it!
And Cycle Cynches are the best.
dO i WANNA KNOW $$$$
$45k-ish for that one with all the carbon fiber.
Looks like a Mondial from the front... Hopefully it is a better bike.
Just make sure your displacement is legal...
Moment of inertia is pretty easy to calculate for simple shapes like a disk. If someone wants a comparison run, provide the inner and outer diameters and thickness, # of rotors, and material (assuming it's all stainless steel) and I'll do the calcs. Can't remember the formula off the top of my head but have it at work. So provide that info for the rim brake disc on the Buell and for some comparison dual disk regular bike and I'll work up the numbers. The formulas is an elaborate version of integral (mr^2), so the radius piece is pretty strong and I'd guess the rim brake is likely higher in inertia.
The EBR rotor is an OD of about 16" and an ID about 12", it's 5mm thick. Ordinary stainless steel.
