2006 gsxr 600 part out
Parts are from a 2006 GSXR 600.
Some parts will fit other year models.
Ill be at most cmra rounds and would like cash, no paypal. 817-907-4134 everything is obo.
Aftermarket Parts:
Ak20 cartridges w/Fork Cap Extenders (.90 spring and .95 spring = 0.925 spring rate)** $750
Race Tech G2R compression and Rebound valve kit in OEM cartridges (1.0 Springs) **$200
JRI MC10 (550lb spring will come with shims.)* $650
Akropovic Slip on with OEM Header $200
Bazzaz ZFi** **$150
Woodcraft Frame Sliders** $35
Woodcraft Engine Covers** $250
Vortex 45T rear sprockets 2 total
Vortex 15T front sprocket
EK SRX2 Chain 520. $100 for all only 2 races on them
Superbike Tail $50
OEM Parts:
Front Wheel with Rotors $275
Rear wheel with rotor and cush drive $150
Rear wheel with Rotor and cush drive $150
Rear Sprocket carrier $75
Swing Arm. $100
Subframe (with spares) $150
Gas Tank with Fuel pump $100
Radiator $100
Steering Stem $75
Clutch Lever with Perch $25
Rear Master Cylinder. $25
Front Master Cylinder $50
Front Caliper Set (will need seals) $50
Rear caliper $25
Engine and Frame Combo $500
I have whats left of the wiring harness with a good ECU.
No title, Clean VIN will provide VIN Check copy
Engine has 11k miles it will need engine rebuild
Ak20s are being rebuilt right now and will be ready to race.
Here are the wheels.
1 rear is pending a sale so I have 1 front and rear left. Wheels and rotors are straight, includes cush drive.
http://i34.photobucket.com/albums/d1...psf0idh81g.jpg
Engine turns over and shifts smooth. For any mechanics this engine is a good deal.
I have a rear wheel, chain, sprockets and rear brake pending sale for an SV rider.
Sale pending on Akrapovic slip on.
Motor, frame, ecu and throttle bodies pending sale.
Sold the Motor and the Frame.
I checked with Bazzaz and the ZFI unit will fit 06 to 15 600 and 750 GSXR's. I have everything needed to download the proper maps for your year model included. (besides a computer)
Brandon- glws, hope to see you back out there soon!
Thanks Jeremy. I'm working at it. Hopefully I will have a bike before the end of the season.
Can bring parts to tws......
I still have wheels, a subframe, gas tank, complete wheels with rotors, sprocket carrier........
Updated list: OBO
Aftermarket Parts:
R&R used aluminum subframe (lightweight) $50
Woodcraft Frame Sliders** $25
Woodcraft Engine Covers (both sides full set)** $250
Superbike Tail $50
OEM Parts:
Front Wheel with Rotors $250
Rear wheel with rotor and cush drive $125
Rear wheel with Rotor and cush drive $125
Rear Sprocket carrier $50
Swing Arm. $50
OEM Subframe (with spare rails) $100
Radiator $75
Steering Stem $50
Clutch Levers (used ASV and CRG levers with a Perch) $25
Rear caliper $25
Ignition set with 2 keys and matching gas cap $200
Race Tech G2R kit is sold.
Updated list: OBO
Aftermarket Parts:
Superbike Tail $50
OEM Parts:
Swing Arm. $50
Radiator $75
Steering Stem $50
Rear caliper $25
This is what I am down to.
Aftermarket Parts:
Woodcraft Engine Covers (both sides full set)** $175
OEM Parts:
3 Front OEM rotors (all straight and within spec) $150 for all of them.
Swing Arm (1 spool is broke off) $30
Rear Master Cylinder and Caliper $40
Ignition set with 2 keys and matching gas cap $150
Bump......
Aftermarket Parts:
OEM Parts:
I can bring parts to Cresson on Saturday, OBO
