I can haz! I can haz! Now to race prep the bike!
Would it be less confusing to call it "Sport" rules instead of Supersport?
Supersport seems too close to Superstock.
Might be easily confused in conversations about the classes (verbal & written)
Abbreiations could be SB,SS,& SP
Maybe I'm overthinking it.......or maybe it's just me getting old with failing sight & hearing
For anyone who missed the first page: Grom Challenge is now official. Supersport rules. No clipons, no bodywork. All oem body panels must remain in place.
Davis Rod & Cycle will be sponsoring this class. But with a twist. Awards will be random and probably completely irrelevant. And may or may not be give to the winner or even a podium finisher. Awards will however be super awesome.
I like this idea.
I wrote up a quick list to clarify what I think the Grom Challenge should be like because I don't think standard supersport/stock rules really apply. It needs to stay a cheap as possible. That way someone with a completely stock Grom can show up and have a chance to do well.
Here's what I've got so far, I'll keep adding as I think of things.
Things that may be removed:
-Rear fender/license plate mount
-Horn
-Blinkers
-Mirrors
-Passenger pegs
Things that ARE allowed. If a modification isn't mentioned, it is NOT allowed.
-Any DOT tires are allowed.
-Aftermarket exhaust, or modifications to stock exhaust
-Air box may be modified or removed and replaced with a clamp on air filter. If using a clamp on filter a brace must be added to keep the bodywork from flapping.
-Throttle body may be turned around 180 degrees from stock.
-Foot pegs may be replaced with aftermarket pegs. Stock rear sets must remain.
-Aftermarket handlebars will be allowed as long as they use the stock clamp locations (1"7/8 handlebars are allowed as long as the stock riser mounting location is used). NO clip ons, NO clubman style bars, NO broomstick bars.
-Braided steel brake lines are allowed.
-Aftermarket brake pads are allowed.
-Aftermarket brake/clutch levers are allowed.
-Aftermarket shocks are allowed.
-Preload spacers in the forks or stiffer fork springs are allowed.
-Chain and sprocket upgrades are allowed. Any aftermarket sprockets must be stock tooth count.
Safety wire list:
-Front brake caliper bolts
-Front axle
-Rear axle
-Oil filler cap
-Oil drain plug
Tape list:
-Headlight taped with your sprint number displayed (side number plates not required)
-Tail light taped
What about a belly pan on the Grom?
No belly pan required. Show up and race your pitbike.
LJB is down for the Grom challenge...
Class unofficially to be known as "junior senior motard"
