Page 29 of 32 FirstFirst ... 192526272829303132 LastLast
Results 281 to 290 of 320
Thread: UPDATED! 11/23/13 2014 Rule and Class Structure changes
  1. #281
    May 2007
    behind you
    I can haz! I can haz! Now to race prep the bike!
  2. #282
    Apr 2006
    Blog Entries
    2
    Would it be less confusing to call it "Sport" rules instead of Supersport?
    Supersport seems too close to Superstock.
    Might be easily confused in conversations about the classes (verbal & written)
    Abbreiations could be SB,SS,& SP
    Maybe I'm overthinking it.......or maybe it's just me getting old with failing sight & hearing
    Bill Klindworth
    68 Still kicking... just a bit slower #737
  3. #283
    Quote Originally Posted by Bill Klindworth View Post
    WERA uses "supersport," iirc. Not sure the difference.
  4. #284
    Senior Member Jesse Davis's Avatar
    For anyone who missed the first page: Grom Challenge is now official. Supersport rules. No clipons, no bodywork. All oem body panels must remain in place.
    Davis Rod & Cycle will be sponsoring this class. But with a twist. Awards will be random and probably completely irrelevant. And may or may not be give to the winner or even a podium finisher. Awards will however be super awesome.
  5. #285
    Senior Member David Proler's Avatar
    I like this idea.
    David Proler, CMRA Expert #65
    Raceworx • Galfer • Vesrah • Sidi Boots • Incase
    212 Decals • South Central Race Center • Pirelli
  6. #286
    Senior Member Ryan Andrews's Avatar
    Feb 2008
    In a van down by the river.
    I wrote up a quick list to clarify what I think the Grom Challenge should be like because I don't think standard supersport/stock rules really apply. It needs to stay a cheap as possible. That way someone with a completely stock Grom can show up and have a chance to do well.
    Here's what I've got so far, I'll keep adding as I think of things.
    Things that may be removed:
    -Rear fender/license plate mount
    -Horn
    -Blinkers
    -Mirrors
    -Passenger pegs
    Things that ARE allowed. If a modification isn't mentioned, it is NOT allowed.
    -Any DOT tires are allowed.
    -Aftermarket exhaust, or modifications to stock exhaust
    -Air box may be modified or removed and replaced with a clamp on air filter. If using a clamp on filter a brace must be added to keep the bodywork from flapping.
    -Throttle body may be turned around 180 degrees from stock.
    -Foot pegs may be replaced with aftermarket pegs. Stock rear sets must remain.
    -Aftermarket handlebars will be allowed as long as they use the stock clamp locations (1"7/8 handlebars are allowed as long as the stock riser mounting location is used). NO clip ons, NO clubman style bars, NO broomstick bars.
    -Braided steel brake lines are allowed.
    -Aftermarket brake pads are allowed.
    -Aftermarket brake/clutch levers are allowed.
    -Aftermarket shocks are allowed.
    -Preload spacers in the forks or stiffer fork springs are allowed.
    -Chain and sprocket upgrades are allowed. Any aftermarket sprockets must be stock tooth count.
    Safety wire list:
    -Front brake caliper bolts
    -Front axle
    -Rear axle
    -Oil filler cap
    -Oil drain plug
    Tape list:
    -Headlight taped with your sprint number displayed (side number plates not required)
    -Tail light taped
  7. #287
    What about a belly pan on the Grom?
  8. #288
    No belly pan required. Show up and race your pitbike.
  9. #289
    LJB is down for the Grom challenge...
  10. #290
    Class unofficially to be known as "junior senior motard"
