Results 1 to 10 of 11
Thread: Swingarm spool bracket broken on GSXR750: Suggestions?
    Senior Member Bob Moyer's Avatar
    Mar 2014
    DFW
    Question Swingarm spool bracket broken on GSXR750: Suggestions?
    My left spool bracket on the rear swingarm of my GSXR750 has sheared off.
    I was wondering if any of you folks have been in a similar situation and if so... I was wondering what you did to fix it?
    I'd like to use my rear spool stand again... but obviously can't right now. If any one has any ideas or fixes... I'm open.
    Thanks!
    Bob
    Here's a pic of the right side with the spool bracket in place:
    Here's the left side with it broken off:
    Senior Member Alan Etheredge's Avatar
    Apr 2003
    Cedar Creek, TX
    ? still got the piece that broke off ?
    Mar 2014
    DFW
    Quote Originally Posted by Alan Etheredge View Post
    Unfortunately... no.
    Jan 2004
    Fort Worth, TX
    Contact Mike at Minette Enterprises. He runs an old school hot rod/fabrication shop near 635 and I35E. He can fabricate the piece and weld it on.
    11586 Reeder Road
    Dallas, TX 75229
    (972) 241-7184
    Sep 2002
    denison,texas
    Quote Originally Posted by Bill Syfan View Post
    11586 Reeder Road
    Dallas, TX 75229
    (972) 241-7184
    Ryan Andrews can also fix it if your local shop can't.
    one tip...you can cut down on the total labor charge if the part is wire brushed, then sanded and degreased(preferably with acetone) before you get to the shop.
    it will kinda give your guy a head start on the repair work.
    it will go faster if you pull the swingarm too. then he can just lay it on the bench and do it in the comfort of a chair.
    plan b would be to buy another swingarm. its almost as cheap as an hour of labor at most competent shops.
    Feb 2010
    Plano TX
    Buy a used swingarm. You can find one for $50-75 bucks. I have sheared them off before.
    Brandon Persell
    CMRA Novice #901
    Triple P Racing/ 2000 SV650 / 2004 GSXR-750
    Senior Member Heinz Roy's Avatar
    Jun 2009
    Quote Originally Posted by Brandon Persell View Post
    Good suggestion...one on there now for $44, free shipping. Depends on your year.
    http://www.ebay.com/itm/11-13-2011-2...-/121551427653
    Heinz Roy
    Novice #458 | BTO Racing #58 (Mini Endurance)
    Not a complete idiot, some parts are on backorder.
    Thanks to...Lucas Oil Products | Dunlop Tires | BDtrackside.com/Vesrah Brake Pads | SoloMotoParts.com | 212Decals.com | Moto Liberty
    Senior Member Sean Gurevich's Avatar
    Mar 2005
    Plano, TX
    Yeah, eBay or just use the rubber pad brackets with those tabs as the stops, which will keep the swingarm from sliding down the stand.
    Get a set of Gilles chain adjustors with the gp lifters and never have to deal with broken spool tabs again.
    CMRA #67
    I have swing arms instock for$50 or i can weild it $50
    469-285-2493 David
    Hypercycle
    410 Calloway Dr.
    Palmer Tx. 75152
    hypercycle@ectisp.net
    469-285-2493
