Page 6 of 21 FirstFirst ... 234567891016 ... LastLast
Results 51 to 60 of 204
Thread: 2016 CMRA Rule Book Posted!
  1. #51
    Senior Member Bryan Hodges's Avatar
    May 2015
    I just finished hard-wiring mine. Here it is off:
    And on:
    It's just an LED accent light(purchased from Cycle Gear) with a switch and 5 amp fuse connected to the battery.
  2. #52
    Quote Originally Posted by Bryan Hodges View Post
    And on:
    Sexy in so many ways
  3. #53
    Katy
    Looks good!
  4. #54
    May 2015
    Thanks guys! It was really easy and only cost around $20.
  5. #55
    Senior Member Bob Moyer's Avatar
    Mar 2014
    DFW
    I dig it... very sexy!
    2009 GSXR 750 (Race), 2001 YZF426 (Dirt), 2014 GL1800 ("Sport" Touring), 2013 Super Tenere (ADV), 2015 CB500F (Daughter's), 2012 Zuma (Daughter's)
    https://www.facebook.com/groups/DQRacing/
    https://c2.staticflickr.com/2/1574/2...888b15cd_n.jpg
  6. #56
    May 2015
    Quote Originally Posted by Walter Walker View Post
    No quick change gear of any kind.
    Captive spacers are allowed under paragraph 6.2, (y). Is there somewhere else that says it's not? I don't follow.
  7. #57
    The light will need to be mounted to pass tech.
    By saying it needs to be mounted to pass tech, are you saying... 1) It needs to be mounted at all times throughout the weekend no matter if it's a wet/dry race weekend? 2) It only needs to be mounted to pass tech, but on dry race weekends it can be removed after passing tech?
  8. #58
    Senior Member Alan Etheredge's Avatar
    Apr 2003
    Cedar Creek, TX
    Quote Originally Posted by Yorke Oldfather View Post
    So, no quickshifter in C Super sport Championship Endurance. We have already bought a front Brembo Brake Master, if I read that right, that's not legal? Does it have to be model year specific or just model specific? R6 Brembo Legal? Our bike fits this class we want to run it, we can disable or remove the quick shifter, but we just spent the money on the brake master. Only problem I see for us right now.
    Thank you the quick reply. And just so I am clear on this, we can or cannot use a quick change axle setup? Captive Spacers?
    Bryan, please note that the 'dialogue' between Walter and Yorke was specifically in regard to the new Supersport Endurance class.
    The allowance you cite is under Superstock rules on page number 22. IF you are running Superstock, that applies to you; if running Supersport it does not.
    There is no specific allowance for captive spacers or any quick-change gear under Supersport items a) through n) on page 24; therefore per the last sentence in that section they are not allowed for the Supersport class.
    The sole endurance-specific allowance for Supersport is that relating to modification of the filler on the stock fuel tank, described in the last section at the bottom of page 34.
    Please read page 34 in its entirety closely .... the Endurance rules for Supersport are distinctly different (and more restrictive in terms of allowed endurance modifications) than for all other endurance classes.
    I'm referring to the page numbers printed on the bottom of each page, not the PDF file page numbers.
    Hopefully that resolves any confusion.
  9. #59
  10. #60
    Sep 2003
    Boulder, CO
    Quote Originally Posted by Shane Zelm View Post
    further, will people just be allowed to run a street tail with the existing tail light intact? Or are we pulling lights off just to put different lights back on?
    Expert #325
    Boulder, Colorado
