Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 52
Thread: EBR 1190RX just unveiled
  1. #41
    Senior Member Ted Phillips's Avatar
    Mar 2008
    New Braunfels, TX
    This is the 1190 RS. If you're in Austin for F1 this weekend (which of course you won't be because you'll be at the Banquet), stop by the downtown location and check it out.
    CMRA BOD 2011-13, 2013-16
    AF1 Racing
    ted AT af1racing DOT com
  2. #42
    Awesome! Is it going to be around for awhile?
    I have to say it made me cringe seeing it held in with the bar straps. I've been using my PB Trailer Restraint so long that anything less looks abusive!
  3. #43
    Mar 2008
    New Braunfels, TX
    It will be there till someone lucky person buys it!
    And Cycle Cynches are the best.
    AF1 Racing
  4. #44
    Senior Member Dennis King's Avatar
    Aug 2011
    Needville, Tx
    dO i WANNA KNOW $$$$
    Amsoil questions, product applications, or how to order LCRamsoil@gmail.com
  5. #45
    Senior Member Jim Dugger's Avatar
    Aug 2010
    $45k-ish for that one with all the carbon fiber.
    CMRA Expert #101
    EBR 1190RX, Large BGE
  6. #46
    Senior Member David Roy's Avatar
    Jan 2007
    Argyle. TX
    Looks like a Mondial from the front... Hopefully it is a better bike.
    David Roy
    Owner
    North Texas Superbikes
    www.northtexassuperbikes.com . 817.845.4051
  7. #47
    Quote Originally Posted by David Roy View Post
    You should get this for Jim so I can stop building this SRAD 600......
  8. #48
    Jan 2007
    Argyle. TX
    Just make sure your displacement is legal...
    David Roy
    Owner
  9. #49
    TX
    Moment of inertia is pretty easy to calculate for simple shapes like a disk. If someone wants a comparison run, provide the inner and outer diameters and thickness, # of rotors, and material (assuming it's all stainless steel) and I'll do the calcs. Can't remember the formula off the top of my head but have it at work. So provide that info for the rim brake disc on the Buell and for some comparison dual disk regular bike and I'll work up the numbers. The formulas is an elaborate version of integral (mr^2), so the radius piece is pretty strong and I'd guess the rim brake is likely higher in inertia.
    David B.
  10. #50
    Aug 2010
    The EBR rotor is an OD of about 16" and an ID about 12", it's 5mm thick. Ordinary stainless steel.
    CMRA Expert #101
