Results 1 to 10 of 14
Thread: Spoken Like a True Texan
    Colin on the Cube "Monday’s fall was my first real ‘contact’ with the system the RS Cube uses to unleash its horsepower. I’ve spent 24 years of my life learning to open up the gas on a racing bike and on Monday I suddenly discovered a completely new way to do it. What actually happens is you give the command to a computer that sends it to the engine. It’s something new and has to be learnt."
    Courtesy of RRW
    Speed Safely, Mike
    Courtesy of RRW
    Speed Safely, Mike
    Re: Spoken Like a True Texan
    Honda better hope he takes a long time to figure it out! Otherwise he will fly by wire right to the front! Smiley
    Mount Rainer
    <div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">Originally posted by Michael D. Henry:
    "learnt."</div></div>Go ahead Chuckster - pick on Colin's English speaking skills when you see him at the awards ceremony. I'll make a point of being there to make certain that you do! :p
    Linz
    Expert #97
    CRRC/CMRA Member Since 1987
    Former and Current BoD Member
    Former CMRA Staffer
    Mount Rainer
    Linz
    Expert #97
    Former CMRA Staffer
    bentracing
    Courtesy of RRW[/QB]</div></div> http://home.earthlink.net/~dvbreeze/
    Might oughta post a link to RRW next time.
    bentracing
    Actually, it's apparent that Colin's comments were transcribed by an Englishman; beyond that, it's as perfectly acceptable to say "learnt" (for "learned")as it is to say "dealt" (for dealed). More properly, one IS "learned" (pronounced "ler-ned", an adjective), and one HAS "learnt" ("lernt", past tense of learned ("lernd"), a verb)). As has always been true, current usage defines correctness, and that correctness depends, to a large extent, upon one's location. Now, where's my Fuller's ESB?
    Former Expert #33, member since 1988, BOD 2001-2004, retired 2008, returned 2016.
    I used to be fast. Ask me about my championships. Bring beer.
