Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Issues with this forum
    Nov 2012
    Houston
    Am I the only person that seems to have a hard time typing out any messages on this forum? As I type it gets slower, starts to skip letters and pauses sporadically. It's really frustrating, is there a setting I can disable so I can type normally?
    Yorke
    Katy
    you might try cycling through your message editor settings - go to your user settings, select general settings, scroll down to miscellaneous options and click a different message editor interface option.
    I switched to the standard editor a while back because it was glitchy for me using IE8 (yeah, yeah, yeah...).
    Last edited by Scott Martin; 01-14-2015 at 09:17 AM. Reason: but I never switched back when I went to chrome...
    Senior Member Ted Phillips's Avatar
    Mar 2008
    New Braunfels, TX
    Quote Originally Posted by Yorke Oldfather View Post
    Yorke
    What browser are you using?
    Certain versions of Firefox have memory leaks and will bloat to multiple gigs of memory usage over a week or two. That would certainly cause behavior like you describe, and a restart of the browser fixes quickly. Don't get me started on IE and its issues.
    Quote Originally Posted by Scott Martin View Post
    Excellent advice, please try this. Some browsers do not handle the "robustness" of the full editor very well.
    CMRA BOD 2011-13, 2013-16
    AF1 Racing
    ted AT af1racing DOT com
    Nov 2012
    Houston
    Ok, I'll check that out when I get home. I am active on 4 forums and this only happens on the cmra forum.
    Frisco
    I use Chrome and havent noticed any issues.
    Senior Member Nancy Selleck's Avatar
    Oct 2002
    Fort Worth, TX
    Quote Originally Posted by Ted Phillips View Post
    Ted, I had the same problem and you were able to direct me to a setting that needed to be changed. Unfortunately, I don't remember what that was though....
    Nancy Selleck
    Retired CMRA Administrator (October 2002 - March 2009, March 2010 - July 2018)
    Mar 2008
    New Braunfels, TX
    I think it was as Scott suggested with the editor interface. It worked for a few other people with other random issues.
    I have setup and admin 4 forums with this same vBulletin version and I can't explain why this particular installation causes headaches like this. One of these days there will be time to sit down and figure it out.
    AF1 Racing
    Senior Member Alan Etheredge's Avatar
    Apr 2003
    Cedar Creek, TX
    This is the fix Ted steered me to long ago. The forum apparently defaults (or did at one time) to the full-boat "Enhanced ...WYSIWYG" editor - the change to "Standard" did the trick.
    TX
    Been having the same problems with IE11/Windows 7. Wil look or this edito seting. (That last sentence is what I get raw when typing. Argh.)
    David B.
    TX
    Yep, that seems to have done it here also. Chose "basic editor."
    David B.
