Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Fort Worth R6 Need Help
    Oct 2011
    My GSXR had a similar issue with a PC3. It ended up being the ignition module.
    Senior Member Allen Dye's Avatar
    Dallas
    Sorry.....way late to the party...
    Ignition coil. These crap the bed from time to time. I don't chase them...I replace them all.
    Did you find what it was??
    Allen Dye
  3. #13
    Senior Member Brandon Orr's Avatar
    Sep 2011
    Fort Worth
    Quote Originally Posted by Allen Dye View Post
    No I couldn't replicate the problem.
    All the cylinders are firing at idle or with the bike on the stand.
    I unhooked all the PC stuff, rode it and it was fine.
    Then I hooked it back up one unit at a time and nothing.
    I believe it is in the PC somewhere but can't prove it.
    I ended up soldering in the PC power cable, even though while testing the clamp was working fine.
    The throttle bodies will still make a lot of noise when powered on, but not as often as before.
    I am going to listen to some R6's this weekend and see what the deal is.
  4. #14
    Dallas
    Well I know this won't help much...
    ...but...
    as my grandpappy used to say; never trust machinery built by a country that never won a war...
    Allen Dye
  5. #15
    Sep 2011
    Fort Worth
    I was really hoping ignition coil, but they were good.
    The bike only has 7k miles on it and the engine has only about 1,000 miles.
    I am guessing it is a connection issue.
