I just finished hard-wiring mine. Here it is off:
And on:
It's just an LED accent light(purchased from Cycle Gear) with a switch and 5 amp fuse connected to the battery.
And on:
Thanks guys! It was really easy and only cost around $20.
I dig it... very sexy!![]()
2009 GSXR 750 (Race), 2001 YZF426 (Dirt), 2014 GL1800 ("Sport" Touring), 2013 Super Tenere (ADV), 2015 CB500F (Daughter's), 2012 Zuma (Daughter's)
https://www.facebook.com/groups/DQRacing/
https://c2.staticflickr.com/2/1574/2...888b15cd_n.jpg
By saying it needs to be mounted to pass tech, are you saying... 1) It needs to be mounted at all times throughout the weekend no matter if it's a wet/dry race weekend? 2) It only needs to be mounted to pass tech, but on dry race weekends it can be removed after passing tech?
Bryan, please note that the 'dialogue' between Walter and Yorke was specifically in regard to the new Supersport Endurance class.
The allowance you cite is under Superstock rules on page number 22. IF you are running Superstock, that applies to you; if running Supersport it does not.
There is no specific allowance for captive spacers or any quick-change gear under Supersport items a) through n) on page 24; therefore per the last sentence in that section they are not allowed for the Supersport class.
The sole endurance-specific allowance for Supersport is that relating to modification of the filler on the stock fuel tank, described in the last section at the bottom of page 34.
Please read page 34 in its entirety closely .... the Endurance rules for Supersport are distinctly different (and more restrictive in terms of allowed endurance modifications) than for all other endurance classes.
I'm referring to the page numbers printed on the bottom of each page, not the PDF file page numbers.
Hopefully that resolves any confusion.
Resolved. Thank you!
