Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Thread: Lap timer??
    Quote Originally Posted by Jesse Davis View Post
    i think something like this is what you guys need.
    Linda likes this idea.
    Nov 2012
    Houston
    I use Harry's lap timer on my old Iphone 4, it's got every track in the world, and I am not kidding either. I use a Dual GPS reciever via bluetooth. You basically use your current phone as a hotspot (you only have to do it once, it may seem like a pain but it's not) and tether the iphone to that, pick the track and that's about it. It's very accurate, i've checked it against my transponder and it was dead on. It's already got the start/finish line and splits, as well as being specific for track direction. It keeps a log of your laps and always shows a reference lap, that you can choose. I made a bracket that's attached to the fairing stay and positions the iphone above the gauges so you look through it as your looking through the wind screen. It works very well, as your heading to the finish line, you can see your target time and the distance to the finish line. It puts everything in perspective, it's also got a green and red meter that tells you if your ahead or behind of your best lap.
  3. #13
    Feb 2016
    College Station
    Will the phone battery last for 6 or 8 hours with the GPS active?
  4. #14
    Nov 2012
    Houston
    I am currently looking at the some of the more expensive lap timers, as I want more data to look at these days. But the Harry's is an accurate and inexpensive way to see what your running, plus the iphone is small and light weight and can be mounted just about anywhere. It's a hodgepodge system, but it does work.
  5. #15
    Nov 2012
    Houston
    Quote Originally Posted by Make McDermott View Post
    I added a usb power port to our endurance bike, and plugged them both into it. I don't use the onboard GPS, I use a Dual brand GPS reciever, it's tethered via bluetooth.
  6. #16
    Apr 2016
    Lewisville,TX
    This is my setup, although I've moved the GPS receiver to my tail section. Top part of the phone case removed for the picture.
  7. #17
    Nov 2012
    Houston
    Here's mine
  8. #18
    Nov 2012
    Houston
  9. #19
    Senior Member Jesse Davis's Avatar
    https://www.facebook.com/photo.php?f...type=3&theater
    this guy is selling home made gps lap timers for $99 ish i think.
  10. #20
    Eric Falt
    There is also a small rod (stick) you can attach to your tank , and see the sun's shadow as you finish each lap!
