Thread: Woodcraft side covers.
    May 2015
    BRAZORIA, TX
    Inquiring if anyone has used the Woodcraft stator cover? I ground a hole in my left side cover and trying to decide if I should go back with the original cover than fit with a plastic cover, or spend the bucks for the Woodcraft with Ss slider. Would appreciate any experience.
    Nov #675
    Aprilia RS457
    Yamaha R-3
    Senior Member Brandon Orr's Avatar
    Sep 2011
    Fort Worth
    I had both sides of woodcraft case savers on my GSXR.
    They were great. They had been in some crashes before I got them. I crashed them more than a few times and never had to replace them or the replaceable slider they had on them. I like their design as you don't have to buy a whole cover again, just a aluminum slider. Which is thick enough it should last awhile unless you crash a couple times every weekend.
    San Antonio, TEXAS
    Blog Entries
    1
    Pretty sure it is a freak accident, they usually last forever.
    VonHertell.com
    Road & Track Suspension
    CMRA BOD 2000-2003
    May 2015
    BRAZORIA, TX
    My mistake, I ground the hole in the original Triumph stator cover. After reading these posts I will be installing the Woodcraft covers. Thanks
    Nov #675
    Aprilia RS457
    Yamaha R-3
