FS: 2006 Suzuki SV650S Race/Track Bike
For sale is a 2006 Suzuki SV650S model race/track bike with 23,800 miles on the odometer, most of them on the street. It was raced at Hallett a couple of times by the original owner, then a handful of track days by the second owner. I was going to do coaching on it this year, but decided to go a different direction. It has Traxxion AK-20 cartridges in the forks, and a Penske shock with remote reservoir, preload, compression, rebound and ride height adjustment. The bike is fully safety wired and CMRA tech-ready.
The bike has a Yoshimura slip-on exhaust system with a short carbon canister, and a K&N filter in the stock airbox. It has braided brake lines and good pads front and rear. I converted the bike to ‘sit-up’ style, with K&N superbike handlebars in a standard SV650 top triple clamp, so it can be ridden all day long during track days, with an oil containment lower mounted. The Woodcraft clip-ons and handlebars, full upper and lower fairing and front bracket all come with the bike if you want to convert it back. The bike has Vortex rear sets, a brand new DID 520 ERT3 gold chain, new sprockets, a front brake guard, adjustable front brake and clutch levers, an aluminum fork brace and a steering damper mounted behind the front number plate. It also has a keyless gas cap, a Woodcraft key switch elimination harness, and a pigtail battery connector for a trickle charger.
It has a new AGM battery and a brand new, never used fresh set of Dunlop 120/165 slicks on it. I didn’t plan on teaching or racing in the rain. The bike has a new fuel pump and the compression and valve clearances have all been checked, and all are in spec. The bolt-on side stand can be used for track days, then removed for racing.
It has a clean Texas title.
This bike has been gone through from front to back and is ready to go!
$4,900
Call, email, text or PM me.
Bill Syfan
817 fivetwotwo 2241
bsyfan at gmail dot com
I am 99% certain that is my old bike, I sold it almost 10 years ago, wow! Everything matches, from the frame slider cut out in the fairings, to the rearsets, grip color, suspension mods, and all. I was stationed at Vance AFB and rode at Hallett a lot, can't say I was ever a racer though.
I'd attach a picture from the day I sold it but can't figure out how on these forums.
What a blast from the past, and it's looking good!
Yes, this was your bike! The bike came to me fully safety wired, so I assumed you did some racing. Your buyer David did a few track days on it and had the suspension refreshed while he had it.
Thanks for the info.
Bill
Very cool. I asked Jim Cambora to safety wire everything when it was there for its suspension/fluid refreshes.
It was well maintained when I had it, oil changes every 2-4 track days and as mentioned above, suspension and other installs professionally done by JC.
Free bump. Hope it goes to a good home!
Price lowered to $4,500. I can deliver the bike and spares to the CMRA round at Motor Sport Ranch this weekend.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
