Results 1 to 10 of 320
Thread: UPDATED! 11/23/13 2014 Rule and Class Structure changes
Threaded View
    Senior Member Ryan Andrews's Avatar
    Feb 2008
    In a van down by the river.
    I wrote up a quick list to clarify what I think the Grom Challenge should be like because I don't think standard supersport/stock rules really apply. It needs to stay a cheap as possible. That way someone with a completely stock Grom can show up and have a chance to do well.
    Here's what I've got so far, I'll keep adding as I think of things.
    Things that may be removed:
    -Rear fender/license plate mount
    -Horn
    -Blinkers
    -Mirrors
    -Passenger pegs
    Things that ARE allowed. If a modification isn't mentioned, it is NOT allowed.
    -Any DOT tires are allowed.
    -Aftermarket exhaust, or modifications to stock exhaust
    -Air box may be modified or removed and replaced with a clamp on air filter. If using a clamp on filter a brace must be added to keep the bodywork from flapping.
    -Throttle body may be turned around 180 degrees from stock.
    -Foot pegs may be replaced with aftermarket pegs. Stock rear sets must remain.
    -Aftermarket handlebars will be allowed as long as they use the stock clamp locations (1"7/8 handlebars are allowed as long as the stock riser mounting location is used). NO clip ons, NO clubman style bars, NO broomstick bars.
    -Braided steel brake lines are allowed.
    -Aftermarket brake pads are allowed.
    -Aftermarket brake/clutch levers are allowed.
    -Aftermarket shocks are allowed.
    -Preload spacers in the forks or stiffer fork springs are allowed.
    -Chain and sprocket upgrades are allowed. Any aftermarket sprockets must be stock tooth count.
    Safety wire list:
    -Front brake caliper bolts
    -Front axle
    -Rear axle
    -Oil filler cap
    -Oil drain plug
    Tape list:
    -Headlight taped with your sprint number displayed (side number plates not required)
    -Tail light taped
