Page 7 of 21 FirstFirst ... 3456789101117 ... LastLast
Results 61 to 70 of 204
Thread: 2016 CMRA Rule Book Posted!
  1. #61
    Senior Member Dave Felio's Avatar
    Feb 2013
    Plano, TX
    Quote Originally Posted by Christopher Corder View Post
    Or are we pulling lights off just to put different lights back on?
    You mean like you already did with your rearsets? And monoshock. And handlebars. And upper fairing. And lower fairing. And tires...
  2. #62
    Sep 2003
    Boulder, CO
    good point Pops.
    silly rule is silly but honestly, I would race with a giant purple plastic weiner strapped to the back if it was required.
    The day I stopped racing is the day I started to slowly die.
    Expert #325
    Boulder, Colorado
  3. #63
    I always thought the rear light idea was a good one.. but I have to ask... how creative are we going to be allowed on this? I ask because it would seem to me that some amount of similar conformity might be appropriate.. and I would hate to put together a system or fixture that down the road is not. I do like the looks of Bryan's though!
  4. #64
    good point Pops.
    Just make sure your strap on has a red light on it.
  5. #65
    Quote Originally Posted by Bryan Hodges View Post
    I just finished hard-wiring mine. Here it is off:
    And on:
    It's just an LED accent light(purchased from Cycle Gear) with a switch and 5 amp fuse connected to the battery.
    Bryan, while I do agree that your light looks cool it may not be exactly what we are looking for. My fault for not being more specific. The Idea is to make the rear of the machine in front of you more visible in the heavy spray being thrown up by a modern rain tire on a gloomy day in the rain. I'm worried that your setup may border on distracting. I'm curious what it will look like in the conditions I mentioned above from behind a wet faceshield. I'm not saying change it, I'm saying lets see how it performs before we pass judgment. In a perfect world It will never get tested but if 2015 was any indicator it likely will.
    Senior Member Bryan Hodges's Avatar
    May 2015
    The photo looks a lot brighter than it really is. I'm confident that it is bright enough to be noticeable from a distance but not glaringly so. With it being tucked under the tail, it's not as in-your-face as it seems here.
  7. #67
    good point Pops.
    Why is it a silly rule? Is it because it may cost the racer a few dollars or is it because its a little extra work to install? It's funny I remember the same thing being said about brake lever guards and oil containment belly pans. All of these items are required in the name of safety. I have a hard time calling anything safety related silly.
    Senior Member Jesse Davis's Avatar
    Quote Originally Posted by Walter Walker View Post
    Fair point, probably something like this.
    Up to 750cc 4-stroke twins, liquid cooled, 4 valve per cylinder,
    Up to 800cc 4-stroke twins, liquid cooled, non-desmodromic valves, 4 valve per
    cylinder,
    Understand we are talking about grafting a pre power valve motorcrosser engine into a gp chassis here.
    right, and im talking about grafting a 250 4 stroke motocrosser engine in the same chassis. its only fair
  9. #69
    Quote Originally Posted by Shane Zelm View Post
    By saying it needs to be mounted to pass tech, are you saying... 1) It needs to be mounted at all times throughout the weekend no matter if it's a wet/dry race weekend? 2) It only needs to be mounted to pass tech, but on dry race weekends it can be removed after passing tech?
    2) It needs to be mounted and functional to pass tech, but on dry race weekends it can be removed after passing tech.
    Quote Originally Posted by Jesse Davis View Post
    The 4-2troke displacement limit for Formula 4 is 180cc.
