Quote Originally Posted by Ben Gooding View Post
That bike would be eligible for the following classes F40-Middleweight or F40 HW, F40 LW, Modern Classic, B-SB, C-SB, A-SB, F2, and Heavyweight twins.....you could add SS classes if you change to DOT race tires.
Not eligible for D SBK nor LTW twins as Jordan mentioned above.
My advice is to run F2, HWT or Modern Classic, F40 LW, & maybe C SB for Sundays
On saturdays you could run Solo 30's or T60's in the LW classes since they use F2 rules!
I have a Duc 749!
Thanks Ben and all, so of all the options, in what class would the 749 have the most equal footing (be competitive)? I'd be coming in as a beginner so my first goal is to not get lapped I can switch to DOT tires if that will level the playing field. I've heard from a couple of instructors to ditch the Duc for racing since it's not competitive, too heavy and not enough top end power. What has been your racing experience with the 749 ?
